It is currently Sat Aug 16, 2025 2:02 am
PostPosted: Wed Oct 29, 2014 10:24 am
Last Name: Sollod
I have noticed that some builders will build 000 12 frets with short scale and some with long... Long scale (25.4) would likely be condusive to drop tunings.
For builders of 000 12 fretters, do you like short scale (24.9) or 25.4?
www.swiftcreekguitars.com
PostPosted: Wed Oct 29, 2014 11:18 am
We do them in 24.625, 25, 25 1/4, and 25.5. Whatever the customer wants.
Stock is 25"...
PostPosted: Wed Oct 29, 2014 11:26 am
I haven't built to many, but I have always use 24.9.
PostPosted: Wed Oct 29, 2014 11:34 am
State: ON
I have built both 25.4 and 24.9. Often I do short scale with Medium strings. I recommend standard scale (or longer) if the customer is going to be using the guitar mostly in drop tunings.
I should also add that I build most of my 000 as 13 fret guitars, but also do them as 12.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Wed Oct 29, 2014 11:58 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I have done both and the 25.4 guitars are my favorite as I use lowered tunings. I did a modern 12 fret with paddle headstock, armrest bevel and sound port at 25.4 and it did not stay with me very long.
Fred
Fred Tellier
PostPosted: Wed Oct 29, 2014 12:19 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
In case you haven't already seen this - some discussion about the Santa Cruz H-13 which uses a long 25.4" scale.
http://www.lutherie.net/model_h.html
Kevin Looker
I'm not a luthier.
PostPosted: Wed Oct 29, 2014 12:51 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
25.4 scale gives you more power and bass. I like this especially if you are adding an extra 1/4" to the depth.
24.9 sounds sweeter and feels more intimate to me. Had one that felt and played like a 00 in my lap which I attributed to the shorter scale and a narrower, shorter peg head.
When I had to decide I kept the longer scale. Dropped tunings, DADGAD & drop D, worked well on both, scale was not an issue.
PostPosted: Wed Oct 29, 2014 1:01 pm
Last Name: Sollod
Should the intended depth of body be factored into which scale you use?
PostPosted: Wed Oct 29, 2014 1:33 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
Pretty sure Martin Vintage 000 12 fret guitars were 25.4, and the 0 and 00 were 24.9. Here is a ton of info on a 1928 000, along with measurements, specs, etc:
http://theunofficialmartinguitarforum.yuku.com/topic/142111/2030s-12-fret-00028-Specs?page=1#.VFEzIod4mS0
Glenn
PostPosted: Wed Oct 29, 2014 4:40 pm
Last Name: Sollod
Glenn,
The 000 12 fret style I was referring to is like Lance's in the post above (with the elongated body). I have been posting about this style lately because I'm planning to build one and trying to decide whether to make it short or long scale and deep body or standard depth. I'm kinda fishin' for builders' preferences. This would be number 11 and I haven't built one before. No customer... unless someone has to have it and makes an offer. I'm also trying to decide if I want do a venetian cutaway to allow for better reach up the neck... It would also be my first slot head. I'm looking forward to it. Part of the excitement is talking about it...
PostPosted: Thu Oct 30, 2014 11:15 am
First name: Glenn
Last Name: LaSalle
sdsollod wrote:
Glenn,
Understood - that was what I was talking about, 12 fret with elongated bodies. I believe the late 1920's Martin 000's were 25.4. The link i sent was for a vintage 12 fret 000 Martin - a lot of excellent info.
Glenn
